Roffle Waffle
- Joined
- Dec 25, 2009
- Posts
- 266
- Reaction score
- 0
Where are they? I searched, and found out that there are 2. I checked all the fuses in the box under the steering wheel, and they all look OK
Have you checked the cig lighter socket with a voltmeter? Have you pulled the center console panel and made sure both of the wires are connected? Have you checked all of the fuses at the PDC?
The lighter fuse under the hood(15A at #4) was blown. I replaced it, and it blew right when I put it in. Disconnected the battery, put in another fuse. Didn't blow it, but still doesn't work. All the fuses under the steering wheel are OK.
I don't have a voltometer
Isn't there a fuse behind the lighter plug also - remember I had that problem also a few years back ...![]()
oh ffs, I was wrong. it keeps blowing that fuse. I wasted 3 already.
yes, a headunit is on that line, but I also dis-assembled the lighter unit to re-upholster that panel. I THOUGHT I put it back the right way. I even took it apart to see if any of the center pieces are grounding on the outside of the housing. I don't have any nerves left for this thing tonight, I gotta get ready for new year's and pack for my trip tomorrow.
i don't have a voltmeter, but I have a tester. I used it to confirm power to all the other fuses, except the cig one obviously blows every time I reconnect the battery
