Clutch fluid keeps turning dark
Great Falls, Montana USA
I try and keep fresh fluids on board all season. I have noticed that even after repeated flushing and a clean refill, the fluid in my clutch reservoir turns dark in as little as 2 or 3 hundred miles of moderate driving. Because I am not running the car on the track, I have been using the recommended stock fluid in place of the more expensive stuff. Any ideas what's going on, and is this normal? (Thanks in advance) JD
J
Let me clarify the problem: the fluid turns a very murky brown in color. Now I might expect this if I were using the clutch hard, but this is just normal day to day use and in a very short time frame as well. It was suggested that the seals may be deteriorating. The cap seems to fit fine.
RockyTop
Roswell, Georgia
Dan, you da man ! This has been observed by many at Viper Days and I know I had a similar experience with flush, refill and prompt discoloration.
Janni
Raleigh, NC, USA
Are you guys actually BLEEDING the clutch system or just refilling the reservoir? There's usually some pretty nasty stuff contained in the line that I think recirculates if you don't do a bleed. Bleed screw not particularly easy to get to, so it can be done - helps to have a little pointy tip on the Mi-T-Vac, as well. Ours get bled and usually can last a season without any discoloration. Alls we get is a little dark sediment on the bottom of the clutch reservoir.
Chuck 98 RT/10
tampa, fl USA
As long as it's clean for tech, that good enough for me.
I had ASSUMED that the rubber boot came WITH a new cap...MY error!! Either way, they DO GET NASTY...not unlike an OLD rubber flapper valve on a toilet.
J
Well, I made the trip to my friendly Dodge Dealer today, to see if I could buy a new "boot" for my clutch reservoir. After looking at the parts list, it seems to indicate that the clutch reservoir parts are sold only as a complete unit ie: ( reservoir & cap, slave & master cylinder with lines ). You can't even buy the stinken cap separate. WOW! Over $300. Any suggestions on where to just get a new boot to stop the deterioration and discoloration of the fluid?
Ulysses
San Diego, CA. USA
You have found out what some of us have unfortunately already run into. You have to buy the whole actuator. Where does one get just a cap and rubber boot? I dunno. Let me know if you find out.
tractor1996
