CEJ
My clutch master cylinder will squeak if I haven't driven my Viper for a couple weeks. It is definately coming from the cylinder, not the linkage, as a dab of silicone grease on the m/c shaft right above the dust seal kills the squeak. After operating the clutch maybe 10 times, the squeak is pretty much gone. I've been told this is a sign that the seals in the clutch m/c are getting old and the unit should be replaced. It's a 2001 with under 13,000 miles.
Should I be proactive and swap out the clutch master cylinder? How difficult is it to replace the clutch master cylinder? Thanks.
