Brandon et al......
The OEM clutch is indeed strong, and a good value at $425 INCLUDING a new pressure plate. But consider that a kevlar hi performance clutch kit includes a stronger/tighter pressure plate @ only $525, I suggest that. The pedal feel is about equal.
You should DEFINITELY consider an Aluminum flywheel now, since no additional labor is required, and the flywheel is $480. The accleration 20-120 gives good seat-of-pants feel, and even improved braking will be the benefit.
Both kits for $979. You will be glad you chose this option!
