The scoop rocks. I'm ordering one. Just some additional info if you haven't ever had your roofliner out...
With the liner out you see the underside of the roof with support structure made out of the same material (SMC) going along the front and sides. There is a double ridge down the center between driver and passenger.
The VERY INTERSTING thing is that there are two rectangular cut outs in the front center through the support beam.
I don't know that it was intentional, but they are perfectly places so that you could cut out only the skin from the outside and have a functional vent.
Now you would have to do something special with the headliner if it were to go back in, but it isn't a big project.
With a die grinder, automotive fastener puller and phillips head screwdriver the entire install could be done in an hour.
How much was your vent unpainted snake keeper?
