Tomer
The pressure bottle (with the rad cap near the fresh air intake) is full full full...Like when I remove the cap, the bottom of the rad cap is touching the coolant...
The overflow bottle hidden in the lower fascia is ~ 1/2 inch above the lower mark...This was cold.
My question, is this OK? My car seems to be running normal per the illustrations in the manual...When run hard or stop and go with higher ambient temps, the gauge reads above the three marks around the 190 "\|/" but it never touches the next mark, which is mid way to the 250...I will call it the 225 mark for purposes of this mail...But it may not be 225. Normally the temp will come back down to the / to the right of the 190...
To potentially complicate matters, the manual said the pressure bottle under hood should be full to the seam, and since it was well beyond that, I got the turkey baster and removed some from the pressure bottle and added it to the overflow bottle via the hose that connects the two...The pressure bottle is still above the seam (i.e. very full) but at least their is a small air gap in that bottle now...
Did I screw anything up?
thanks! we are planning a trip this coming weekend from the SF bay area down to Santa Barbara, so I want to make sure the snake will be kewl.
Tomer
96 RT
Tomer
96 RT
