-RUNNR
Site programmer
Pulled the snake out of the garage for the first time this winter, and took it for a spin. Went down to the gas station, filled up and did the usual oil check.
While I was checking the oil, I noticed what looks like corrosion on the throttle bodies and alternator. Anyone ever have this happen? What's the best way to clean it up?
Also, got a check engine light (car is stock other than smooth tubes). Going out to check the code now that I found my book. Hopefully nothing serious...
EDIT: Just realized how worthless my Service Manual is. It says in section 8E-15 to turn the ignition on-off 3 times, and read the code in the odometer. Ummmm.... Hello? Dodge? My odometer is analog.
