could really use some help here!
Danino
I have a silver 98 GTS and I've been wanting to put stripes on her. I've searched high and low and I can't get the measurements of the stock stripes from anyone :dunno:. If anyone knows or could measure theirs for me you would be a big help. I just need to know the width of the stripes and the space between them. Thanks for the help...
my viper
enthusiast
Chicago
1996 Stripes = 209mm(8.24") - 100mm(3.94") space
1997&up Stripes = 203mm(7.99") - 112mm(4.41") space
Stripes on 96's went through the plate area.
plumcrazy
ALL OVER
SEARCH FEATURE
Almost every question you can think of has already been asked and answered! In some cases, the information may be out of date and a new thread will be needed, but in many cases, an answer to your question may be under 10 seconds away!
The VCA Web Forums has a search feature very similar to web search engines like Google. By typing in a few words, it will search all old posts since the website was created to find words matching what you typed in. Be mindful though, the more words you type the fewer results you will get as it will try to find posts only with all of the words you types. In saying that as well, by using words like “The” and “It” you will get hundreds if not thousands of threads. I might suggest sticking to main words. Also try to avoid year specific searches. It will block out a lot of good info. For example:
“What is the best exhaust system for my 2006”
It might be better as:
“best exhaust”
To do a search, click on Search located in the center of the Directional Information Toolbar. If you are wanting a quick overall search, just type in the words in the search box. For this example, we will go with an Advanced Search as you can further clarify your search parameters.
Once you have clicked on Search, click Advanced Search located under the Quick Search field.
Type in the key words you want to search for. Once you have typed in your key words, click on the drop down arrow on the Search All Open Forums tab located on the lower right side of the Search page if you would like to clarify your search. Choose a specific forums you would like the question searched under. In some cases this is not needed but if you are wanting the best exhaust for your 2008, you will not want the threads from the 1992 cars. This feature helps to cut down on the amount of non-applicable information that will be presented to you. Do remember though, by selecting the one section you are narrowing down the number of places the search will look. If there was a thread in the Racing section, and you only selected the SRT section, you will not see that information. This menu can be useful if used correctly.
Once complete, click Search and see your answers! Feel free to play, there is no limit to the amount of searches you can do!
D
Danino
THANK YOU SO MUCH!!! It's been hell looking for the measurements. By any chance would yo know the paint code to the Blue on your car. I think I have the wrong one...
zoomie
Owings Mills, MD, USA
from search:: paint codes
Viper Wizard :
Default Re: Paint Codes
Hi Mikael,
1996 Viper GTS Blue Pearl-Coat, Code SBE, PPG Paint Code 19282.
Touch-up "Brush" Part #4864082[blue]
1996 Stone White Clear-coat, Code SW1, PPG Paint Code 5072.
Touch-up "brush" Part #4864104[white]
Re: Paint code...
Your paint code should be on the manufactures plate typically located on the driver's side door in the jamb area. On my '01 GTS it is at the bottom below the bar code and looks like PNT:pRN. PNT for paint, PRN for red.
speedracervr4
Lancaster, PA
I found the PM that Burt G sent me. This was for my 99
Required Blue Stripe paint code: PBE (Pt# 04864082AB)
Required Silver paint code: PA9 (Pt# 05010886AA)
PDCjonny
Just go 8" wide with 4" between them no one will know the difference.
tractor1996
