D
DAMN YANKEE
Guest
Great decision, you wont regret it.
Now...the narrow band question....
85% of your driving is "closed loop" with the engine using your four (4) narrow band sensors (along with other sensors) to be sure your car is staying in the interactive adaptive curves. Yea, with simms your not getting engine lights now...guess what, your not getting your adaptives reacting either. Your car gets zero feedback...nice, everything must be ok cause my engine light is off, right?
There is also a dirty little secret about the stock Viper open loop curves, the stock curves are too lean in the low RPM range (up to 4,000) and too rich in the higher RPM range. AND THAT IS THE STOCK CONDITION. Without the wideband(s), you will never have a clue as to what your car is doing BEFORE all your headwork, etc. etc. and no ability to tune the rig with an engine management system.
Your going back into your exhaust right? Get it ALL done.
My guess is that you do not still have the two at the header and your asking if you need the two at the rear. Well, IMO, you need all four put back in (**** the header or the transition pipe) and while your in there do yourself a big favor and put in a wide band on at least one side as well for when you go WOT and slip into "open loop". Buy a Vec and get then you can actually tune your car and get it to run well. Its simple, there is absolutely no comparison between a well tuned car that has narrow band feedback working in closed loop and one that does not. AND...there is no comparison between a built engine with wideband and the ability to finally adjust fuel and spark in open loop and one that just has the stock PCM.
How hard is it? Piece of cake.
