MR VENOM
Just ordered my EBC Greens from John B. Do I need any special tool(s) to install them? I read other posts about "cleaning up" the rotors.
HOWEVER, it is MUCH easier with the tool.
No, not really. To return the rear pistons the manual indicates to use a special tool but one is not needed. Use of a pair of needle nose pliers was all I needed. To use the pliers you insert the two ends into the holes and rotate the piston. Similar to a spanner wrench in function.
The fronts only require a drift punch.
Should be nothing more than a 1/2 hour job plus the time to remove the wheels.
Plus the time to thoroughly sand and clean the rotors prior to EBC installation.
