Venom Lover
I haven't dyno'd my Viper since getting smooth tubes, so I figured I'd go do a run today to see what they bought me. The dyno results are shown below. The blue power curve is the curve from a month ago before smooth tubes. The green and red curves are today's runs with smooth tubes, and as you'd expect, they start out above the blue curve. However, around 4700 rpm the curves cross over, and in fact the results show I'm making 431-433 peak rwhp now vs. nearly 450 before. UGH!
So, just for my own amusement and another $25, I put the stock inlet tubes back on (and checked the filters in the air box while I had it off -- they looked fine), and we did another run. The results were nearly identical to the other results from today. Same shaped curves, same crossover with the curves from before at about 4700 rpm. About 2 rwhp less at peak with the stock tubes.
So that made me really confused. We checked for arc-ing on any of the spark plug wires, and nothing. All I can think is that this run was with the Purner slick set-up that I have on the rears, which are I believe about an inch larger overall diameter. The dyno guy said for sure that would make no difference on the power vs. rpm curve, but I have to think that's the difference. The car ran 11.73 sec at 120.35 mph on Sunday at Carlsbad. I can't possibly be down nearly 20 hp, can I???
Any thoughts? I'm going back tomorrow with the street tires on the car to do a re-run. I'll let you know what happens.
(One interesting thing I remember is that somewhere around 4000 rpm an interesting deflection started occurring on the sidewalls of the rear tires above the dyno drum....I will guess that deflection somehow results in a decrease in the torque measured by the dyno and thus affects the power measurement....)
