dyno question
jkracer9
Cypress, Tx.
Maybe this is not important but. Prior the dyno the dyno tech enters Temp, CF etc. If the outside temp is 95degrees but 70 was entered as the outside temp would that make a diff. in the numbers or not. Same thing if it was 70 degrees and 95 was entered would there be a diff. Thanks in advance
Venom Lover
Santa Barbara, CA USA
It will make a difference in the corrected results, but not in the actual results. The correction will account for temperature. I don't know how much of a difference 70 vs. 95 would make in corrected results -- maybe 5%.
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Venom Lover on 03-29-2002 at 11:50 PM</font>
tractor1996
