Eibach spring question
Qualitywires.com
Louisville, KY
not sure about your answer, but did you notice a difference when you had the springs put on? A big difference in appearance? Any way you can post a pic?
TOOOFST
Barrington,il
The spring is forgiving until it start to roll then stops.Its a tighter ride and looks better eh!
The technical reason is the ABA STASHA STRATUS AM KINERKA J.
Jim Hodel
Portland Or
Progressive rate springs are designed to ride better at lower speeds. The progressive rate springs I've seen have the softer coils farther apart at the bottom of the spring, with the coils getting closer together toward the top of the spring as the rates stiffen. You get a softer ride over bumps at slow speed. but as you start driving harder, the springs stiffen up.
It is a good compromise for street use, although most pure track set ups use single rate springs so that handling balance is not upset by differential stiffening between front and rear springs.
Jim
rharon
