Engine Mount Install Question...
ViperTony
I'm working on a detailed writeup on how to install engine mounts. I'm using the PolyBushing's mounts. For those of you that have installed these mounts on a GenII Viper, is there a specific LEFT & RIGHT mount so that the "tabs" face the same direction as the OEM mounts after they're installed? I have a call into PB but thought I'd check if anyone else came across this during your installation.
Here's a pic of my Driver's side OEM mount, the tabs face out towards the front of the car. If I install the PB mount, the tabs will face the other direction. I'm thinking I may have received two driver's side mounts:
PB Mounts:
Thanks,
- Tony
ruckdr
Renton, WA USA
There is no difference - right or left. One set of 'tabs' will be toward the front of the car, the other set will be toward the rear. The 'tabs' are a safety interlock only.
Later,
V
ViperTony
Thanks Don. PolyBushings got back to me earlier and confirmed the same. - Tony
tractor1996
