Exhaust change
GTSnake
Motor City
I'm planning on changing my exhaust this spring. (If and when it ever gets warm up here again!) I'm putting in a 3" system from headers on back.
Do I need to replace the flex pipe with a similar 3" one or will the header kit (Belanger?) come with the necessary connections?
Jack B
NE Ohio
Make sure they include a welded 90 in your kit, the first Balenger exhaust kit I bought had a weld-it-yourself turn-out. In addition, do not use their gaskets, get the latest Mopar (steel sandwich) gaskets.
Mike Adams
guelph, Ontario, Canada
If you get a B&B complete system everything you need is included. The flex pipe is not necessary I have not had one in 4 years no problems. If you do want B&B and need some one to install it you may want to make the 3 hr drive to my shop and I can install it for you. You can even stay an watch or help if you want.
Mike Adams
GTSnake
GTSnake
Motor City
Thanks for the offer Mike. I already bought the Mopar Cat backs and want to get the Belanger headers. I guess I'll have to make sure they include all the miscellaneous pieces with the headers.
Besides, I've been through Guelph many times on the way to TO. I don't think I can handle the traffic :D
