There is finally scientificly based research (based on science but not actually scientific)that clearly defines the fastest color for an automobile.
While scrounging around I found this from Poudunketr University (good ol PU). Not to be confused with the research from it's rival university, Frankefat University. (You know, old FU) The research is too extensive and complex to post it here so I will just summerize the results. The new, bright colors were not tested but can be assigned to there relatively close colors.
Green - Green tends to blend with verdant background found in most US areas in the summer. This causes other drivers to not see green cars and then crash into them, greatly reducing their speed.
Black - It was found that black cars absorb radiant solar heat which slows them down considerably. (No evidence was given as to why radiant heat slows down a car. I think this was just a masters degree research paper).
White - White cars tend to reflect radiant solar heat, which also slows them down.
Red - Red Cars are very fast, however....... they also attract the police and get pulled over more than other colors. This slows them down considerably.
Yellow - Also very fast, however.........They really attract insects. Go to a car show and you will see the bugs love the yellow ones. Insects on the car reduce aerodynamics and add weight thus slowing the car.
Copperhead Orange - Copperhead Orange is easily visable, is light enough to not absorb or reflect too much radiant solar heat, does not unduly attract law enforcement, and is not extremely attractive to insects. Therefore.........
Copperhead Orange IS THE FASTEST COLOR!!!
