First time at a track, oh yea
jkracer9
Cypress, Tx.
Last night I finally made it to the drag track, first time ever, what a blast. I put on a set of slicks and went to the Baytown track (out side of Houston). Enjoyed myself so much I only hope the money holds out to continue this. I can see where it might be cheaper to have a d*** habbit.
I do not have a full roll cage so I was told if I ran under 12 sec in the qtr mile I would be asked to leave. First run in the 60 foot was 1.662, the 1/8th was 7.356 at 95.91, went through the 1/8th and let off of the gas and still showed a 11.93 through the 1/4 mile. We were told that we had one more chance so I was really watching myself and started breaking after the 1/8th mile. My first time ever track numbers were 7.837, 7.764 & 7.799. The burnout got easier everytime and was a blast. I will be back out at the tract for the next 3 weekends before VOI in hopes of a better launch.
I thought it was against the law to have this much fun. What was your first track experiance like, how did you feel after your first run?
Had to share this with someone.
Rohn
jp
Umea, Sweden.
Hahahaaaa, there is no way back... burnt two clutches and broke one differential this season and it's still fun... :)
Rock On!
Motor City Mad Man
Las Vegas, NV
Wow, your runs look as good as your car.
Were you using slicks or drag radials? Great 60' times, wow.
varanus
pleasanton,ca 94566
Did you run slicks or drag radials. Which tires did you run up front? If you mixed did you notice any handling problems?
Diablo Joe
Lakeland,Fl
Rohn,
Those are great times.Its so much more fun on ET Streets isnt it?I ran mine for the first time on the ET Streets a couple weeks ago and went 7.51 @ 97 mph with a 1.68 60 ft.I was slipping the clutch when I could of just dumped it .I know I can cut a 1.5x 60 ft and get my times around 7.3x.If you get your 60 footers around 1.5x youll knocken on sixes through the eighth.
Joe
King GTS
Houston, Tx.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jkracer9:
Rohn
<HR></BLOCKQUOTE>
Well thanks a whole lot Rohn! I would've loved to come out with you!
I went to Astroworld.
Great runs though. Were they motor only runs or did you have your NOS on?
J
jkracer9
Cypress, Tx.
Trey, you are invited next time for sure. Your coaster runs were above the 1.6"s and 1.7's we were making.I will call you this week, I might rent the sealy track for the afternoon.
Just motor no added fun to the run.
M/T slicks w/ firestone skinnies. I drove to the track w/ the tires and yes it handles much different. It is one of the better rushes in life.
Vreracing
Amarillo,Texas,USA
Sounds like you had a great time.
Pretty amazing that they almost wouldn't let a stock car run because it might be too fast.
<OBJECT WIDTH=320 HEIGHT=240><PARAM NAME=movie VALUE="http://vreracing.com/Viper/Vipercorvair.swf"><PARAM NAME=quality VALUE=high><PARAM NAME=scale VALUE=exactfit><PARAM NAME=menu VALUE=false><PARAM NAME=bgcolor VALUE=bgcolor="#eeeeee"><EMBED src="http://vreracing.com/Viper/Vipercorvair.swf" quality=high menu=false scale=exactfit WIDTH=320 HEIGHT=240 swLiveConnect=true TYPE="application/x-shockwave-flash"></EMBED></OBJECT>
ViperGear
