Fluidyne rad and air box Question
VIPER BAZ UK
ENGLAND
Just fitted a fluidyne rad and wondered what you all did to get the airbox to fit again...
New brackets??? or new airbox???
Bottom of air box now hits fan shroud...
PhoenixGTS
Phoenix Arizona
Not a big deal!
You drill two more holes in the airbox
That is what I did. Just moved it rearward a little over an inch with my PWR radiator. I hold it down with fender washers and nylock nuts now. I made a new crossmember bracket and used a clip on nut-cert so that position uses the stock thumb screw. Had to shorten the smooth tubes also - they are stubby now:
V
VIPER BAZ UK
ENGLAND
Drilled two extra holes and i had a little K&N filter rubber bush that i had left over so i used that for the cross member support..
tractor1996
