Fog light switch (rear)
carl B
United Kingdom
Finally bit the bullet and cut the switch into the dash.
I recon it looks OK??
VIPER BAZ UK
ENGLAND
Just run the wire for mine what a pain.....
Up from the lighter up behind the rear panel cover down through the harnes bolt hole and through the rubber **** next to the battery into the trunk......
Baz
Warfang
California, East Bay
is this for aftermarket foglights? or is it to move the switch from the main light switch? I have a 97 gts for reference. maybe the 99-02 are different?
luc
Paso Robles CA
You can get a factory headlight switch with the built in rear fog lamp function.
as the "regular" switch it's made by Ford and I can give you the part # if you want.
Luc.00GTS
PS: I wanted to add rear fog lights on my car, so I got the switch,but never finished this project.
luc
Paso Robles CA
I will post the part # tomorow when I get to the office.
The nice thing when you wire it "correctly" using the factory "export" switch is that the rear fog light icon in the instrument cluster will work since it's already there on all Vipers (at least on GenII)
Luc.
luc
Paso Robles CA
The switch is manufactured in Germany by Ford and the Dodge part # is : 04 76 35 96
retail was $33 in 2001
Luc.00GTS
Both Stacks Blowin'
United Kingdom
Hi Luc,
Is it possible to post a picture of the switch?
I believe that I know what the Ford part is and it would be easier for us not in the US, to get this part from Ford rather than try and get it from Dodge, as they do not exist outside the US!!!!!
:confused: :confused: :usa: :confused: :confused:
luc
Paso Robles CA
The switch look exactly the same than the "regular" one and has a bunch of numbers:
G952A
13096/097
13102/104
95BG 11654
You should be able to get it from any Jeep dealer,it's what I did in the US
tractor1996
