Fuel Pump DIY?
Matt M PA
Langhorne, PA USA
I looked up my print-out of this from when I did it on my '96 RT. These are the ones "ticked" on my instructions...
1.
Power supplied with key-on (zero volts when key-off, 12V when key-on)
a. In a Gen 1, connect red wire to A21 14DB (dark blue)
2. Ground by PCM to complete the circuit (infinite ohms to ground when key-off, cycles to no resistance to ground when key-on.)
a. In a ’96 GTS, connect green wire to K51 20 DB/YL* (dark blue/yellow stripe)
3. Any solid black wire ground for the taillights
a. Connect to black wire
Puntacanaviper
