Gen 2 seatbelt harness
Jance GTS
Oklahoma City, Oklahoma
Quick question. Do all Gen 2 GTS's have the harness cutouts behind the seats? Or is that just an ACR feature since it comes with a harness?
Thanks!
MTGTS
Orlando, Fl
the mounting points are there but only the ACR's have the slots in the bulkhead. I took my bulkhead out and made my own slots.
Richard Koch
Bremerton, Washington
I just finished putting in Team Tech 6 points in my 1999 RT-10. On that year the threaded sockets for the eyebolts behind the seat are a bit of work to get to. I had to find 2 tiny dimples in the plastic bedding material behind the seat (after removing the rear console) and then grind a hole to open up each threaded boss. Other than that, it went fairly smoothly by following the directions I found in the forum. I think that other years are a bit easier than my 99.
Leslie
Indiana
The teamtechs are nice! They are padded a bit so are very comfortable, and they are designed to' pull in' to tighten. I personally think that's easier than pulling belts
Away from your body to tighten. You can also get them in different colors and stitching.
tractor1996
