rpm9000
Does anyone know if Gen.2 tb's will fit on a Gen.1? If so would it be worth changing them out. I know the Gen.2's are larger in diameter.
I put them on mine. I think my car runs better now. I swapped out the linkage mech.'s from the gen.1 to the gen.2 's. Took a die grinder and made the hole bigger in the manifold and drilled a hole in the side of the drivers side intake tube close to the throttle body and hooked up the evap line. No codes.
I think it's one of the many things you can do to the gen.1's that all add up after a while.
