aries
I was wondering what the difference is between the Gen 5 and Gen 4 engine? Is the block and heads and stuff the same just with the internals being different? Is the architecture the same or are they two totally different designs?
that brace needs to be in carbon fiber!
Performance Cross Car X-Brace
With single-piece carbon fiber construction, this hand-made brace has more than 30 layers of carbon fiber optimally aligned to manage driving loads. Brace features topology optimized structurally efficient design, aerospace-grade stainless steel attachment bushings, and significant weight savings over production aluminum engine brace. Polished, exposed carbon fiber weave complements hood inner finish. Front, carbon-fiber cross-car brace.
MSRP: $3,175, part number 82213416
I like heat resistant red, to go with the valve covers. Carbon fibre is so cheaply imitated these days, hard to tell real from fake...
As best I have been able to find out:
-Nearly identical block, heads, and peripherals
-Forged pistons- but dont be fooled, these will not be equivalent to aftermarket parts.
-Sodium Filled Exhaust Valves- NOT Larger.
-Revised camshaft intake lobe duration.
-Revised Intake Manifold.
-Revised Valve Cover/Coil Cover arrangement.
In short, from what I can see, there is nothing as part of the Gen-5 that could not be adapted over to Gen-4 architechture. Take a Gen-4 block, put in aftermarket pistons, a Gen-5 Cam and exhaust valves, and a Gen-5 intake manifold or ported manifold... and you have basically the same engine.
Dan, thanks! What do you guess would be the hp/trq upside to the Gen V cam and exhaust valves (on a G4 with headers, ported intake and heads)? any other advantages? thanks! Mike
Its hard to tell until after a Gen-5 cam can be checked out. The Gen-4 cam is not small, I would not be surprised to find out there is a misrepresentation of the info: IE barely no change, same cam with a different installation, actually a programming change for phaser and not an actual cam change, etc. Our ACRX/USGT engines make WELL over 640 on the G4 cam, and without headwork- its not small as I said. My feeling is that the cam change is minor, and the gains are primarily via manifold. Until we have an idea how good the manifold is, and if the cam is actually changed and by how much [cough... Gen-5 might not be the only option soon either ...cough] we are shooting in the dark. Its not impossible the ideal configuration may actually turn out to be a ported Gen-4 manifold. Who knows.
The Gen-4 exhaust valves will have near zero affect on HP. They are simply trying to keep the valves cooler on extended high RPM running at high loads found on track duty. It helps ward off detonation.
The Gen V camshaft has the same exhaust profile and timings as the Gen IV cam however the intake profile has been change to improve top end breathing with a very slight loss of low and mid-range. The lifted area under the curve is greater and the intake centerline is ******** four degrees. This change alone would result in an 8 to 10 horsepower improvement compared to the gen IV profile. The cam change would be a direct swap; the intake centerline should be checked and set to 122 ATDC. Although some calibration changes were required for Gen V, our guess is that the Mopar controller would provide acceptable fuel and spark and since many of the OBD monitors are desensitized there should not be any issues with check engine lights. All bets are off with a production controller.
There would be zero difference in HP & TQ if SRT would open up the Gen 4 PCM for a more aggressive tune - especially if headers and intake mods were accounted for in the Gen 4 .
Gen 4 would probably even rate higher ....
Not sure what you mean?
But on that topic, I would LOVE to get someone with a Gen-4 to install a Pectel and actually see what these cars can make on a REAL tune while staying N/A.
If your providing the pectel, I'm there I thought you owned a gen 4?
I thought I'd try lol. When is your car going to be finished?
I'm pulling my Belanger Headers and HF cats from my Gen IV before trading the car for the new Gen V.
Will also keep the Mopar PCM, MGW engine and trans mount, along with the MGW short shifter mechanism.
Any idea if they will fit the new Viper ?
If not I'll just put those up for sale
Let me know if you decide to sell those parts.
They had a slight problem with certain cylinders running hotter than the average. You can change the a/f and timing based upon the temps of the upper cylinder chamber. The factory has always dumped loads of fuel (over rich) at wot to cool the charge, that costs hp.
