Gen I head gasket/cylinder liner and [******]/speedline wheels?
Magicboy2
Philadelphia, PA
Plenty of info if you search about the head gasket issue.
General concensus is that all Gen Is will someday need the head gasket replaced.
Tom Sessions
Hampstead,NC.
tne frame issue is recall 998and 999 and this effected 96 thru 00R/T and GTS cars.What year is your car?If it is a 92-95 R/T you have nothing to worry about.
FRANK
Somewhere in southern NJ
Head gasket issue is really not an issue. Just get the new updated gaskets and your problems will be over. I believe Chuck Tator has done about two dozen head gasket job with 100% success. I just swapped new ones in my 94 and no problems whatsoever...
Bad_Byte
Corpus Christi Tx
I don't think the wheels are the 2308's at least not the one's I have. Mine have a center cap to cover the really ugly hub in the center.
Bandit3
Atlanta
backus, is your viper less than seven years from the in service date?? If so, I have a solution. John
ROIII
