gen1 differential swap question
mrbob
davenport iowa
with a lot of gen2 rears with bat wing on ebay can you swap a gen2 in a gen 1 would like to do a gear change and keep my stock gen1 :)unit complete , thanks to all
Jack B
NE Ohio
yes - the only difference is the diameter of the pinion shaft and since you are not mixing parts it will work.
Dan Cragin
LA, CA
Gen 2 will bolt up. You will get the super 44 with no drain plug. You need to machine the top pad for the track bar. For advice please contact a vendor on the site who will give you support.
ROIII
