Thanks for all of the input!
I'd get some Motul or SRF brake fluid, SS brake lines, and fresh pads.
fresh engine oil
How old is your coolant? trans fluid? diff fluid? clutch fluid?
Make sure your helmet is SA certified and not just M certified.
Are your 3yo tires PS2's?
Ahhhh, lets see here. Yes, they are PS2's.
And Helmet is SA.
Fluids, diff has been done, engine oil obviously done, the rest is factory. BUT, the car has 5300 miles on it. Should I be changing everything still or????
Also brakes are all original too. Barely seated!
SRF, I can boil Motul and then your brakes go to the floor with no warning. When racing anything for the first time, always tap the pedal quite a distance from an upcoming brake zone to be sure you still have brakes prior to the start of your braking area. Lots of cars lost by not doing that.
That is great info! Thanks!
Mopar Boy...good for you !!
I remember an excellent talk given by Jim and Kathy Stout at an Ohio VCA Party in March about two years ago...complete with a printed prep and tech sheet. You might contact Jim and ask for a copy...and, if that fails, send your fax number to me in an e-mail and I will dig up a copy and send it to you.
Have fun, Dude !!
P.S....don't be surprised if they assign an extra few hundred pounds of weight to your car...as an equalizer...because of it's obviously faster due to the YELLOW color !!!
Thats great info! And yes, Jim and Kathy's talk this year is where this all started!
I have badly wanted to race cars since I was about 7 or 8 and have intentionally avoided taking the car to the track for fear of liking it too much. Its a slippery slope. But its time.
LOL. At the speed I plan on driving I think even the red cars will have a chance at beating me!
I think that unless you have a bunch of track weekends under your belt, you won't be using your brakes hard enough to boil the Motul. It is possible; if you are extremely aggressive or over use the brakes; but, I do not believe that 98% of folks starting out have a need for SRF. Most don't even use Motul at first. But, you certainly want fresh fluid and I think that you can't go wrong with the Motul.
Excellent. Thank you.
As for the blue "film," I think that you are seeing the 3M painter's tape that lots of people put on.
Really? Thats it? I always thought they were large sheets like 18" wide!
Guess not!
