WESTCOAST JASON
Before I say anything here I MUST praise DLM and Vipermed (scott). They have both, for no profit of their own, walked me through hours of tech support help with my Turbo car. Without them I am certain that I would not have found the problem/solution to my detonation/spark knock headache.
Thank You Doug. Thank You Scott.
That being said, I can finally announce that all 10PSI is being put into the motor with 91 octane gas and the car is NOT pinging or detonating.
The problem was so stupid I am almost embarassed to say it, but here goes.
During another day of changing/reading plugs and trying different combos of fuel pressure, retard settings (both on MSD and Piggyback) and plugs I was under the car checking on the flex pipes (thanks Scott, new ones are still fine!) and figured since the car was in the air I would check the fuel filter.
Yep. That was it.
The car has a intank pump still in place (it is a 255LPH Mustang unit from Summit I had installed back in the NX days) which feeds to the CPR (Aeromotive type) billet filter and then to the 1000HP CPR (Aeromotive) pump. I decided to check the fuel filter so I took it off and put it on the bench.
Upon opening it (the unit is a reusable type billet case with a purolator filter inside) I found that the filter was a bit dirty but looked fine. However, I put it to my lips and it was hard to blow through. hmmmm..... I went to the autoparts store and got a replacement and it to was not 'EASY' to blow through. Turns out it is a '10 micron' filter for what thats worth.
Instead of putting the new one back in I figured I would try without one as a test. I took the car out and it felt the same at 5psi. Oh well I thought. While driving back I realized all the retard was still programmed into the box. Ooops... I put the piggyback at zero retard across the board and just put the MSD @ 1 for testing. Wow, the car pulled great! I had not felt the 5 psi setting feel so powerful before.
I pulled over and cranked the manual boost controller up to 10 psi and drove again. Ear to ear grin, felt almost like the NX kit used to. Drove around a little more and was thinking maybe I should pull more timing out (no detonation to this point).
Low and behold, I was able to set the MSD to .5 (point 5) which pulls 1 degree of timing out for every 2 psi of boost. Now the car greatly SURPASSES the seat of the pants it used to be like with the NX (300HP) setting!!!!! I have now put a solid 300 miles on today alone and run 2 tanks of gas so far. PURFECT! I love it. Pulls SOOOOOOOOOOOO hard! 4th gear - 3000RPM (about 75mph) roll ons are the greatest! Smoked every street bike I could find on the freeway today with power to spare. I am AMAZED that a stupid filter could do this to me!! ARGH! Just the wrong part for the application I guess....
Scott and Doug both talked about it though and Doug SPECIFICALLY kept reminding me that fuel pressure is not fuel flow. I was told over and over that flow is important also. Right on the money guys! Now I just need to put the inline filter back in with a free flowing filter. Who would have ever thought? With that fixed and the oil control problems fixed by my ANGELIC-like, long distance phone techs, there are but a few minor (in comparison) issues to deal with.
Anyhow, thanks guys (and gals) and to all that have supported me with tech tid-bits. I know more about boost and Vipers than ever and it is because of this board and its members. Vegas and So. Cal members, PM me for your rides, no more cancels!!
Thanks again VCA!
Yep. That was it.
Thanks again VCA!
