To finally have a clean, high end mounting system for the cannisters. As I am sure you all saw my initial design which came out really nice. Since I was planning to go in production with these brackets, I decided to improve upon the initial clamp style design.
The new design will feature a fully hinged bracket with a quick release mechanism to make it a snap to remove and adjust the cannisters as needed. Here is the design:
For those that have seen the setup in person, they are truly amazed. At the recent Pocono event, the Viper guys were extremely impressed with the look and quality. Again this is the perfect compliment to the $4,000 Moton setup and to the Viper. Moton should have offered something like this from the beginning.
The rears mount to the trunk rear section with one bolt and C nut and the fronts mount on the cross member with one bolt each. All that is required is to drill a hole through the cross member. This picture is the initial design. The new design above will look similar but much nicer and much more functional.
The package, which fits all 03-06 cars without a paxton, will include two front and two rear brackets, fully assembled. It will also include all mounting hardware as well. The price of the brackets will be $195 for the four brackets, not including shipping. The brackets will come with a polished finish (see pics below), but we can custom anodize the brackets to your color preference. In addition engraving or shallow pocketing for a more custom look can be done for $5 per set depending on what you want.
For you guys running a paxton or guys with 08's, if I can get 10 or more people interested, I can develop something for you as well.
Here is a close up so you get an idea of the finish. (again old design but look and finish will be similar.)
Considering these are CNC'd from aluminum blocks and a custom, one off design, the price is a bargain.
I will be producing 20 sets in the first production run. This will be first come, first serve. I have 6 sets already spoken for. If you are interested let me know. If we get enough interested and can go to another production run, the price will come down further.
If interested reply here or PM me.
Tom
917-520-7337
Tom
917-520-7337
