FLX109
I was told by a mechanic if you decide to change your calipers over to another set (say you buy powdercoated ones/exchanged) you can minimize bleeding the brakes if you fill the new calipers with brakefluid to the top through the line hole, disconnect the caliper brake line keeping it high so you do not drain fluid and connect to the new caliper then mount and all you might have to do is add to your reservoir under the hood, has anyone ever heard of this?
FLX109
FLX109
