TexasPettey
I took the car in today for inspection, and I failed the HC emissions tailpipe test. Not being an expert in this area, I did some research. From what I've found, high HC can be caused by incomplete burn, rich mixture, or bad cats.
I'm thinking I'll do plugs and wires, although my wires are only 2 years old and my plugs 1 year. I can use the VEC3 to lean it out a bit on the low end. I've got a ROE exhaust with high flow cats that are 2 years old. Any thoughts regarding replacing the cats?
Any other ideas around HC? Could the O2 sensors be getting old?
