Head gaskets
Viper Scot
Inverness, Scotland
Would it be an adviseable precautionary measure to replace the head gaskets on a '96 RT-10? And, if so, how much would this precedure cost?
Bill B
Plantation, Fl. 33323
If you were going to do the heads at the same time I'd say do it now. As far as precautionary that is up to you. If they start to leak change them. The gasket kits are about $800
Viperchad
Pittsburgh, PA
Absolutely!!!....had mine done under warrenty last summer by the dealer. Total shop bill was around $2K. Should do the thermostat too while you're at it.
Viper Wizard
South Salem, NY USA
Upper engine gasket set from Dodge #4626640AD MSRP $960.00 :eek: [through me -20%]
It takes me about 7/8 hours to do the job @$90 per hour.
You will have to do it at some point.
All GENI head gasgkets will need to be replace! Some sooner then others.
Estespropaint
