BADVENOM
This goes out to the NJVIPER and the viper owner from Michigan in reference to their post on heating their garage.
First of all anyone attempting to install heating in their garage better be qualified. I don't begrudge the do it yourselver, however in this case a licensed and insured professional heating contractor should be the choice.
Reason? Because, if you value your life, your familys life and your property running gas lines or oil lines, for that matter is a job for a professional not to mention, electrical work.
Just for your reference any additional piece of heating equipment
installed in a home must be filed with local municipalities to become on record a part of your home..Lets just say by some freak accident something was to happen, like a fire you would not
be covered in your homeowners insurance policy, not to mention the unspeakable, death..aka Vitas Geralitis..Professional tennis player who recently died of CO AFFIXIATION.
And yes, forced air systems are preferable either gas, oil or
fan coil units because of their abilitys to recover quickly. Garages generally have a lot of cold air infitration.
Always use a vented unit to outside air, doesn't necessarily have to vent into existing chimney as there are direct vent units
by either Modine or Reznor. Check with your local plumbing or Heating Supplier or call a heating contractor.
Last but not least.Do yourself a favor and research before doing.
THE LIFE YOU SAVE MAY BE YOUR OWN
Adam.........Licensed N.Y.C. Master Plumber #1003
May the force be with you!
