I definitely recommend you upgrade your half shafts if you have plan to run more than stock power or use drag radials or slicks. I broke two heavy duty half shafts making only 466 rwhp with stock radials. The second time it took a chunk out of my differential housing.
I, like you, believe that it's better to break a half shaft than to blow the transmission or something else, but I believe the stock half shafts leave a lot to be desired in terms of strength.
I also recommend the half shaft loops. They're relatively inexpensive and buy you a lot of security.
