Oh, I see how it is
Paolo Castellano
Reged: 11/01/00
Loc: Elburn, Il, USA
Gentlemen, now get the transmission ratios Dodge SHOULD have put into the Viper!
#5818 - 03/27/02 09:25 PM Edit Reply Quote Quick Reply
Hello, anybody here want to be able to use 6th gear to go fast instead of just for gas mileage? There is a guy who builds race transmissions for the Corvette racing teams who is a master rebuilder for Tremec that has come up with a way to put a .80 ratio for 5th and a .62 for 6th instead of a .74 5th and a .5 6th. In stock 5th gear the Viper would top out at 205 MPH @6200 RPM. The stock Viper .5 6th gear is way too low of a torque multiplier to go as fast as the car can go in 5th. With a stock 3.07 rear end gear, and a .8 5th, @6000 RPM you would be going 185 MPH, (Good for Just about any road course, I believe), --> Now you shift into 6th and will be at around 4600 RPM( Turbo and Supercharger cars will shine here!) By 6000 RPM you will be going 238 MPH! (Assuming you have the power to push the car that fast!) Erik Messley went 227 MPH with 650 Hp Caldwell Motor @ 7400 or so RPM. Also Road race guys, check this out, put a 3.73 gear in the rear end, and now you have effectively added another usable gear to the car which can still go 203 MPH @ 6200 RPM. The 3.73 rear end gear combined with .62 6th is almost identical to the stock 5th gear with a 3.07. If a 4-speed is faster than a 3-speed, then, a true USABLE 6-speed will be much faster than the usable really only 5-speed in everyone's Viper! He is currently building NEW t-56 that has a custom main shaft( With additional oiling journals) and cluster shaft that allows the retention of the stock 1st-4th Gears while allowing the .8 5th and the .62 6th gear sets from some of the mustang and camaro t-56 trannies that have gear ratios similar to those on the Z-o6, 1st 2.97,2nd 2.02,3rd 1.43, 4th 1.00, 5th .80, 6th .62. Before this, you could not interchange the 5th and 6th gears because of the cluster shafts 1st gear ratio determining what 5th and 6th ratios you actually get.-> the .8 and .62 got underdriven beacuse the 2.66 on the cluster shaft would spin 5th and 6th faster than the 2.97 1st would. Anyway, he has rectified the problem by making custom shafts that accomodate 2.66 1st, 1.78 2nd 1.30 3rd, 1.00 4th, .8 5th and .62 6th. If anybody wants to go to
http://orbitdevelopment.com/vipergears/gears.asp , you can play around and see that this is what Dodge should have done. $3,000.00 and your old trans as a core exchange will get you a NEW t-56 transmission with the ultimate gear ratios, a main shaft with additional oiling journals, carbon rings, cast iron shift forks, and a 12 month/12,000 mile warranty. To inquire additional information, you can email George @
viperzo6@aol.com. The o in zo6 is the letter o, not a zero.
IMO 1. for road race guys this is huge for adding an additional gear( allowing a numerically higher gear ratio in the rear end for a higher percentage of time spent in the torque peak). 2. for HIGH HP freaks, they can go 238MPH in .62 6th with the STOCK 3.07(With the proper amount of HP, of course). 3. Guys with a stock car can now put in a 3.55 or 3.73 gear, have phenomenal torque multiplication without sacrificing top end speed! This is the Bomb! Paolo
1996 GTS being supercharged by Heffner's Performance!
