VOI94of100
My '06 coupe is not getting fuel. Must the fuel tank come out in order to replace the fuel pump? Are there sensors in the fuel system that would prevent the fuel pump from normal operation? Also, the quick connect on the fuel rail for the braided fuel line appears to be different from the ones used on earlier snakes... Do the Gen III OEM connectors also require a special tool to disconnect them? I'm going to try and connect a temporary pressurized fuel supply to the fuel rail just to be able to move the Viper to a location where a transport truck can get it to a dealership.
Any recommendations will be greatly appreciated! - THANKS.
