Help, wiper problem
GTSJERRY
powder springs, Ga
Hi guys i am having a problem with the pass. side wiper on my 96 gts, drivers wiper works normally, pass side moves and inch and stops moves a little more and stops. Anyway i replaced the pass side wiper motor and i have replace the wiper control module. Just wondering if anyone has ever run into this problem before and if someone might know what else could cause this.
Thanks Jerry
ruckdr
Renton, WA USA
GTSJERRY,
I have the same problem, herky, jerky passenger side motor. I have a replacement driver's side motor sitting on the bench; haven't gotten around to installing it yet. Are you saying a new DRIVER'S side motor did not fix the problem?
Later,
99 R/T 10
Enterprise, AL USA
I still have the set of wipers off a 93 that were in great working condition. If anybody needs a replacement or spare, aapm me.
SYNFULL
Bucks Co, Pa
Ulysses is right. My passenger wiper was doing the same thing. I replaced it twice because I thought the first replacement was bad. Finally I replaced the drivers side which was working- and that solved the problem
tractor1996
