Help with a misfire
Viper Wizard
South Salem, NY USA
Hi Richie,
First question: Are the spark plugs and wires ok? If ok it may be the coil pack? I have had coil packs do similar symptoms with temperature
,they drive me
at times!
Let us know how you make out.
Cheers
The Year Matters...kind of. You do not mention the mileage on the Viper. I suspect over 12,000, the point at which plug wire misfires begin to occur. The 1992-1994 wires were WORSE.
"Leads" is the Brit word for Wires....Try new Leads, of the Hi-temp varity.
Agree w/ Chuck, the coil packs can be troublesome, but new plugs and new wires will "probably" end this problem.
I will ship to J-Burg if you care to order. THANKS
