I followed the manual and took off all the bolts I can see. The manual does show two bolts on the underside that I can not find. I can move the radiator back and forth but I wont come up. Only thing I can possibly see that is restricting it are two steel wires (less then a 1/2 inch wide) that goes around the radiator (top to bottom and seems to out the bottom). Are those suppose to be removed. What am I missing. Thanks for the help.
