Hi-fow vs no cats, (will be supercharged eventually)
Invasivore
Ft. Lauderdale, FL
I have to make the decision now whether i should go with high flow vs no cats. Right now, i just have a cat back and smooth tubes. I will be supercharged hopefully within a year though. Is there a substantial difference in power potential when i put the paxton on it?
g3t_t0rk
Probably 0 difference in whp gains. I got no cats cuz I've had too many problems in the past with them clogging up! Plus they sound so much meaner and flames out the tailpipes is a plus :)
Fuoss484
Tyrone PA
I have the cats deleted on my GTS. This winter I will be putting some high flow cats on.
As of right now, I get a lot of exhaust fumes in the cabin, if the window are down. Windows up, no fumes. Read somewhere that a high flow cat will correct this.
Really dont think it will hurt HP significantly, with the paxton (but not an expert on this).
speedracervr4
Lancaster, PA
I run high flow cats on my Roe car (since 06) and I've had no issues. I've been told it will lower your HP by 5-15hp, but I would rather not deal with the soot or fumes.
Fuoss484, Have you checked your rear exhauster vents in the truck compartment? They fall down sometimes and allow more fumes in than normal.
uvbnbit
Kingston Springs, TN
I ran catless for 6 yrs. great sound. got tired of the fumes, stains on bumper, clothes in trunk smelled. Maybe i just getting old :D. I put hi-flows on this spring and LOVE IT! car has a better "tone", no exhaust smell, it actually feels "stronger"? I hear what you lose in HP, you gain in a bit of TQ. They say "some" backpressure is good. I did a search online and found a ton of scientific, engineering stuff that was waaaay over my head on that topic. :omg:
I have 2 3" cat delete sections. make offer :D
DrumrBoy
GA
Don't delete the cats for WHP gain....you won't notice anything at all. Delete them (as I did) for the sound and for the sill heat lowering properties of going catless.
NO HEMI
In front of a corvette..
Very interesting read, so going by what he said , me having no-cats and just
One small bullet muffler on each side ( even though it's loud), is probably the best setup for my hp range!!!:cool:
brentsGTS
Pull the cats for better power. Plus it will sound better and have lower temps. Less restrictions equal more air being allowed in! Besides only ******* run cats. ;)
Blainne
Sierra Vista, AZ
I have Hiflow cats and my sills stay cool, but I'm even up in the air going catless for the sound. (Viper had Hiflows on it when I bought it.)
catless, the sills are ice cold. not heat at all, even in summer. you wont have to worry as much when you add boost. the SC cars tend to run rich causing cats to clog. when they clog, they can cause severe engine issues, dont ask me how i know
Jack B
NE Ohio
I have personally seen two major cat caused fires on modded cars. Early Roe's also had an isse wirh cats igniting due to a rich a/f mixture.
I
Invasivore
Ft. Lauderdale, FL
I think im sold on going catless. I don't want any potential for a fire, i plan on keeping this car for a long time. Plus I didnt even think about if I wanted to run leaded fuel on a good tune
I
Invasivore
Ft. Lauderdale, FL
BTW, has anyone made near 700 rwhp on pump gas on a stock motor with a paxton and headers? I hear about this Novi 2500, but haven't thoroughly researched it. There are pesky GTR's in the area that I think have trap speeds in the 136-138 mph range. I know it will take about that kind of power to match them.
you live in the same town as DLM, go talk to doug, nobody knows more about paxtons on vipers
Bill Pemberton Woodhouse
Blair,Nebraska,USA
Keep in mind going catless is going to make it hard to resell in many States and frankly the comments on fumes in the car and around should be taken notice -- we had a ton of complaints over the years from customers who modded and then wanted to put them back.
I
Invasivore
Ft. Lauderdale, FL
Are these reports of fires from only the stock cats or modded hi-flows as well?
Dom426h
DE
Prob mainly stockers & older hi-flow ceramic substrate ones.(failing)
The hi-flow metal substrate ones are suposidly more durable. Makes sense to me since they flow better meaning less heat buildup. Only downside is that since they flow like a straight-pipe they Sound like a straight pipe.(as where the ceramic ones aid in taming the sound)
Yes, the fumes of going catless can get to you. Do you wear contact lense? Keep an extra bottle of clear eyes drops in the glove box:2tu:
Kkustelski
