Hit something... NOW Weird Noise - Help
BlackACR
Rowlett,Tx
It is probably your fuel pump. Once they get older they make a little noise. Also, check your fuel filter, could be straining the fuel pump.
MES
Sarasota, Florida
You probably cracked open a seam under your car with the 2X4 The noise was always there, but now you can hear it because of the crack/hole. Look under the car for the 2X4 impact and see if you see anything.
