This is another on of those $64,000.00 questions.
These cars all run around 205 to be exact, in heavy traffic, but will cool down to around 185 in fifth gear at highway speed. This tells me the car has a 185 thermostat in it, but the cooling system is unable to maintain that in traffic. As many of you know, most temp sensors, that being the device that kicks the fan on, will go through a cycle and kick the fan on at around 205 or more, then run till the temp drops to a certain level. The SRT's fan when running at full speed, still can't bring the temp down on the car as well as high gear at highway speed can. One or more of the components in the SRT cooling system, are just not able to cool the beast as it should. I don't like the car running that hot, as I know it's only about 20 more degrees over that, and you've killed the engine. It's gotta be ******* it. Kills horsepower also.
Some people will say we need a higher volume water pump. They think that's the weak link, well I think not, because the car cools right down, on the highway, at 1600 rpm, and the water pump is really turing slow at that speed. Kick the car into forth gear, watch the temp go up. The Viper creates a huge amount of heat at higher rpm, and I just don't know what it's going to take to cool it down. The radiator may possibly be to big, and not create enough water velocity. Big rads. are good when the going gets really tough, but they are lousy for normal sporting about. I really don't know where to start.
Let's all give some input on this, and maybe we can come up with an affordable way to get this car to run at 185 all the time. If you could get the fan to come on sooner, that would not bring the car down to 185 in traffic.
As I said on the highway it falls, and it's because of two things, lower rpm, and much needed forced air. I say both of these things, because I did a test and loaped around town at about 40 mph, in a gear that kept my rpm down to around 1600 and the car still ran hot. So this proves it takes air volume and low rpm to keep it cool. Maybee that hydro fan is not cranking out enough cfm. Maybe a set of dual electric fans, and a lighter smaller radiator would do the trick. When I was in Texas, summer heat around 104 the car would not even drop to 185 on the highway, only come night time, did it cool down. Winter really brings some cool air into the front of the rad. The car runs cool even at 40-45 mph. Archer has a $1,000.00 mechanical water pump with increased volume. For that much you could device the best electric water pump system made, and run the best dual electric fans on the market. Then for around $600.00 we should be able to have a custom light weight rad.
Skip White
