how much does the hub stick out? Anyone know?
KDR83
Tampa, FL
I am having spacers made for my car that I want to be hub and wheel centric however the spacer is only 3/8 thick so I am not sure if the hub doesn't stick out more then that or around that because if that is the case, obviously I can only make the spacer hub centric, anyone happen to know how much the hub sticks out? I don't have access to a jack so can't take the wheel off to measure it.
K
KDR83
Tampa, FL
:confused: Could you re-state the question?
The hub sticks out a little past the rotor, its basically a ring that sticks out in the middle, the rotor sits on it and if your wheels are hub centric they also rest on it, just trying to see how much this "ring" sticks out
you can see this ring here
it will stick out less then this because of the rotor's thickness
K
KDR83
Tampa, FL
Maybe after I have this spoiler put on...it's getting shipped as we speak
Thanks:2tu:
iownedu
You will only be able to do hubcentric to the hub with 3/8". Can't do hubcentric to the wheel.
tractor1996
