How To Change Spark Plug Wires on GEN II
Toronto_ACR
Toronto, Ontario, Canada
I would really appreciate somebody detailing to me what has to be done to replace the spark plug wires on a 2002 ACR. What is the easiest and best way to do it. Any phots would be appreciated. i dont have a member shiop to go to the how to section.
Please Help
Leslie
Indiana
pm sent I have some detailed installation instructions that may help from a VCA member
2001 GTS
Charlotte, NC
Take off the cowl at the base of the windshield and the intake for the AC, then R&R each wire one at a time. Pretty simple job after you do it once.
AJT
Houston, TX , USA
Make sure you push them onto to plug hard, usually you will feel a "click" when it is all the way on
Chuck 98 RT/10
tampa, fl USA
You might as well replace the plugs at the same time.
Remove windshield wipers
Remove windshield cowl.
Remove heater box.
Replace the plug wire and its spark plug one at a time. I use an air hose and blow out the area around the plug before removing it.
aelimos
