Since I have the hood off and Viper up on stands I snapped some pics for you. I've take the fascia off a few times and I can do it under 20 minutes now, even less when I'm working through a 6 pack. Pics with some notes.
Driver's Side Fender Well:
Passenger Fender Well:
Top of Fascia:
*Note you see bolts in the pic above. I used to have tree fasteners which I removed and tapped the holes for actual body bolts. You may also find shims under some of these bolts. Don't lose them and keep track of where they were and how many in each location.
Front of Fascia:
The fasteners under the headlights are FUN. I think there's one under each headlight. Be patient and try not to scuff/scratch the fascia below the headlight as you work loose the fastener.
Fascia Underside-Middle:
Mine looks different from yours because I have the Roe Front Fascia duct installed.
Fascia Underside-Left:
Fascia Underside-Right:
When I remove my fascia, I lay it on a few moving blankets so it doesn't get scuffed/scratched. It's a one person job to remove and install but two people simplifies installation/removal.
If you decide to replace your tree fasteners with bolts let me know and I find which tap/bolt size I used.
Hope this helps.
(yeah, I know the fascia is filthy. It's on my to-do list)
