maverickagm
The problem:
My mechanic told me I needed a new clutch safety switch. I did not. The actual problem is the clutch pedal has some left-and-right wiggle. As you press on the clutch pedal, the pedal arm catches on a bracket. You think it's bottomed out, but it's not. Wiggle it to the right and you can push in further, then the clutch switch is engaged. The first minute of this video shows the problem:
www.youtube.com
The fix:
Replace the clutch pedal shaft bushings. Unfortunately they wear out rather quickly. If you plan on owning your car for awhile, you'll be changing them more than once. The method below creates an access hole to replace them quicker. Even if you manage to get custom bronze bushings, the access hole will make them easier to re-grease.
Items to buy:
2x Clutch Pedal Shaft Bushings. Mopar Part number 2467770 (or 02467770). These are discontinued. They were used on some 60's and 70's Mopars as well. www.brewersperformance.com carries them. Their part number is "CPB770". It is 0.500″ inside diameter, 0.560″ outside diameter. Part number "FD1770" from www.yearone.com might work as well, but I am not certain.
1x Birdcage bushing for the clutch rod to clutch pedal arm. You have a couple of options here. Mopar part number 4643448. Crown Automotive also makes them with the same part number. If you're concerned the plastic bushing might break at the worst possible time, you can swap the birdcage bushing for these two parts:
* 1x Clutch Actuator Bushing. Mopar part number 4446361. Viper Parts Depot SKU OEM-632
* 1x Chrysler Metal Clip (it has multiple uses). Mopar part number 4581512AA. Viper Parts Depot SKU OEM-633
If you think your Birdcage bushing is in good shape, buy a replacement anyways because it will almost certainly break when you try to remove it.
1x 2" flush mount body plug
Tools:
* Drill
* Small drill bit for pilot hole.
* Flashlight (headlamp)
* 2" hole saw
* Something to deburr your hole. rotary tool, sand paper, file.
* Needle nose pliers
* Flathead screwdriver.
* 10mm wrench
* Socket wrench. 15mm and 10mm sockets.
* A grease that's safe for metal and plastic. I used Super Lube Synthetic Grease.
* Magnet
* Masking tape
* Metric ruler or digital calipers
* Fine tip felt.
Instructions:
1) You probably want to remove the drivers seat. I forget the socket size. Put seat all the way forward and remove two rear bolts. Put the seat all the way back and remove two front bolts. There's not much to it. Also the knee bolster. 5 screws.
2) Open the hood and remove 3 10mm nuts on the washer fluid reservoir and set it aside. I didn't have to disconnect anything. There's plenty of slack.
3) Place a piece of masking tape under the 2 top studs from the washer fluid reservoir. From the top edge of the tape, measure 11mm down. From the center-point of the top-left stud, measure 40mm to the right (Yes my photo shows 39mm. 40mm is slightly better). This will be the center-point for a 2" hole.
4) At this point you could drill a small pilot hole at the center-point from step 3. Shine a flashlight into it and find the light from inside of the car to see if you're satisfied with this spot. However, you don't have to take my word for it. To measure yourself, go inside the car and use a (very strong) magnet on the metal side. Align it with the pedal shaft, as if the pedal shaft extended all the way to hit the sidewall. On the outside of the car, use one of the 10mm nuts from the washer reservoir to locate the magnet. drill a pilot hole, leave the drill bit in the hole, find it from inside of the car, and readjust. The idea is to locate the center-point of the pedal shaft from outside the car. Decide on a hole size, then drill a new pilot hole for the center of your hole saw. The hole should allow you to fully remove the pedal shaft, and help you reach the birdcage clip.
5) With your hole-saw pilot hole decided and drilled, start cutting with a hole saw. I wore out a wood-cutting hole saw doing this. I cut partway, then with the imprint already made, I used a very small drill bit to drill holes all around the circle, then enlarged each hole with a slightly larger drill bit, then finished off with the hole saw again. Finally, use a tool to deburr your edge. Do a good job of deburring the edge.
6) Using your new access hole, remove the E-clip with needle nose pliers and an flathead screwdriver. Next remove the washer behind the E-clip. If you've positioned your hole well, you should be able to use needle nose pliers to remove (break) the birdcage clip attaching the clutch rod to the pedal arm.
7) Wiggle and pull out the clutch pedal from inside the car.
Post continues below...
![www.youtube.com](/vca/proxy.php?image=https%3A%2F%2Fi.ytimg.com%2Fvi%2FB-tjxHo9phg%2Fmaxresdefault.jpg%3Fsqp%3D-oaymwEmCIAKENAF8quKqQMa8AEB-AHUBoAC4AOKAgwIABABGGUgZShlMA8%3D%26rs%3DAOn4CLBv0MHOR_cyp1nR9KGVi6HCI3eDMA&hash=1f5cc9c5e7ef88143b68bf0a13a840e5&return_error=1)
Gen 1 Dodge Viper clutch pedal and shifter repair
Quick video to show what I did to fix dodgy clutch pedal bushes and a loose shifter in my Viper
![www.youtube.com](/vca/proxy.php?image=https%3A%2F%2Fwww.youtube.com%2Fs%2Fdesktop%2F9e7b5b42%2Fimg%2Flogos%2Ffavicon_32x32.png&hash=1dd7c59ff69ec990279e230c8e382a7b&return_error=1)
The fix:
Items to buy:
Tools:
* Drill
* 2" hole saw
* 10mm wrench
* Magnet
* Masking tape
* Fine tip felt.
Instructions:
