Viperzilla, what do you mean screw up the 04 holders?? There is no certificate program for the 2004 cars. I guess if you sunk the cash into one of these cars you might understand, but in your case it's easy to sit on the sidelines and spout off.
It is not because DC is dealing with this problem a little beter than with the liner issue that they are doing it corectly.
A little better than bad is still not good.
That said, if you car was using 1qt evey 350 miles,DC could not have denied that the engine was defective since by the car manufacturers own VERY relax oil consumption guidelines,anything a more than 1 quart per 800/1000 miles is considered to be a big problem (may be would not even pass a smog test)
You could have used the Lemon law and get reimbursed for rentals,lease,etc.
Y2K3SRT, we have not been offered a new motor like you were. Many of us don't care about the gift cert., the rental or the promise of a quick fix - I have had my car since March and it has yet to be repaired - real quick fix. In fact if you have been following this, like you say, you would have noticed that the majority of us would gladly give up the rental and gift cert for a new motor, or at least to have the motor sent back for a proper repair. Also, where and when did DC apoligize to me profusely?? Did I miss it??
To address these issues in order-Viperzilla, what do you mean screw up the 04 holders?? There is no certificate program for the 2004 cars. I guess if you sunk the cash into one of these cars you might understand, but in your case it's easy to sit on the sidelines and spout off.
Again, is there a way that the 200 of us affected owners can get together and make a stand against D/C. Apparently, those that are not effected or do not have an SRT do NOT CARE!!!! I personally, will be writing to the auto mags. Not that it will do any good, but at least I will be proactivie instead of passive.
The bottom line is that Craig has a very legitimate gripe. However it has NOTHING to do with the recall, as neither he or his family are affected by it in the slightest. It appears to me that Craig and his family were screwed out of at least one, if not two SRT-10's. The valves have nothing to do with it. Craig, I love ya man! But your issue is another one entirely. I would love to see a post on THAT one sometime so that we can get rightfully indignant about the way you are being treated by DC. The valve issue isn't it.
Chris
PS. Ask the early Z06 owners what Chevy did for them when they were burning oil. Answer? I believe not a thing unless they took them to court.
My GTS needed the door opened to fix a window motor when it had about 50 miles on it - that makes it less valuable?
asp, I'm not trying to pick a fight, but this is one I spotted right off the post, to which you claimed you answered yes. So a Viper with a blown window motor is more valuable than one with a functioning one just so the door isn't opened?Mike,
The answer to ALL of the questions, except the certified letter, is yes.
Well, what if I told you I could change the plugs, or air filter; doesn't mean I can do it/have experience on a Viper. I'd be wary of them, which you are doing. But I can also tell you I can drive a Viper and cheuffer you if you'd like, I have had a couple experiences like that.When I asked why she recomended that dealership she simply said "because they told me they can do a valve job".
