I just had my A/C blower motor burn up and smoke the entire cabin while trying to turn it on. It would not come on and I left the ignition and A/C fan switch on trying to figure out what the problem was when all of the sudden "SMOKE" from under the dash on the drivers side appeared. AWWW $HIT!! I can smell something burning. Talk about a panic attack. Holy crap, I turned the ignition off then I ranned in every direction from the trunk to under the hood to under the dash (smoke still coming out) back to the trunk then to my tool box looking for I don't know what cause I don't know what I need at this point trying to find the fastest way to disconect the battery cable.
Anyways, I finally disconnected the + cable flom the fuse box up front under the hood (2 hex nuts VS 10 bolts on the battery cover in the trunk).
It turns out the blower motor has corroded and it ceased up although I'm not sure how condensation could have accumulated in the motor while operating.
Took it all apart to look for any burnt wiring and there was non that I could see. Anyone had this problem before.
I have the Max Care warranty from Chrysler and I wonder if this blower would be covered.
