C O D Y
There are many people here that have no clue about pistons. Some will say that I fall in that category, but I thought I would share my experiences.
I will preface this with the fact that I have two vipers and I stayed at a Holiday Inn last night. One viper with forged pistons and one hypereutectic pistons. Between the two there are over 100,000 miles on them and I can tell you what I have experienced.
FYI: 1992 to 1999 FORGED PISTONS / 2000 to 2002 HYPEREUTECTIC PISTONS
The reason people have labeled some motors creampuff is because of the hypereutectic pistons. Hypereutectic pistons are actually favored because of reduced scuffing, improved power, and fuel economy. The reduced thermal expansion rate allows the piston to be run with reduced clearance, which reduces losses due to gases escaping past the sealing rings.
Unlike forged pistons where you will get piston slap when starting a cold motor because of the thermal expansion
The term 'hypereutectic' comes from eutectic. Special melting processes are necessary to ‘supersaturate’ the aluminum with additional silicon content. Special molds, casting and cooling techniques are required to obtain finely and uniformly dispersed silicon particles throughout the material. This produces pistons that are very hard, thus brittle. For this reason they are great in naturally aspirated engines, but should be used with caution for 'nitrous', super- or turbochargers. Generally speaking, forged pistons are a better choice for high boost. After 20,000 miles on my hypereutectic pistons I haven't burn ONE DROP of oil and no piston slap.
Bottom line, if you are going to add forced induction, go with forged.... if not, you will get more life out of the hypereutectic pistons.
