Induction Concepts??
Jbud
I heard from a friend that the guys at Induction Concepts (http://www.inductionconcepts.com) were looking for a Viper to start their twin turbo prototype on? Think he said they'll be ready to start in the next 30-45 days?
Has any one talked to them or have an opinion?
The kit they just finished on a Mach 1 Mustang looks incredible and put down 511rwhp on 8psi and pump gas with a completely stock motor...and that's only from 281ci.
They said something about letting up on the throttle part way through the run, gun-shy about the boost controller they were using, then getting back into it. I looked at the dyno sheet and you can see where it happened. I think if they would have stayed in it, it would have made close to 600rwhp at the same boost level.
J
Jbud
I'm not sure, the Stage I system on their site says $15,800. It also says the turbos that come in that kit will support 1600hp. I think the main difference in their three different stages is whether or not they build the engine and drivetrain to support the power, and probably the fuel system.
But they will have to have a car to prototype on first, which is what they are looking for now.
