Fuel pressure is not a monitored system. So I run an aftermarket fuel pressure gauge on my piller so I can see it all the time. Sending unit is in the old shrader valve location. Hangs out around 52-55 psi...but that assumes a correctly calibrated gauge.
The last time I was at the dyno, we logged fuel pressure from the shrader valve location and I plan on doing the same this time. I didn't have these mods then but fuel pressure went from 58psi to 56psi at WOT. I'll see if I can get a data logger to capture duty cycle info.
